Author Topic: Engine&tranny  (Read 4459 times)
Offline dirtydeedss
Engine&tranny
« on: February 23, 2006, 07:30:35 PM »
will an 1800 bus motor fit onto a bug swingalxle tranny??
Offline 68IIIbuggy
Engine&tranny
« Reply #1 on: February 23, 2006, 08:06:58 PM »
It will, but as far as I know you will need a special flywheel.
Offline dirtydeedss
Engine&tranny
« Reply #2 on: February 23, 2006, 09:37:28 PM »
whats the difference in the flywheel??
whats involved in changing the flywheel do i have to split the cases??
Offline 68IIIbuggy
Engine&tranny
« Reply #3 on: February 23, 2006, 10:01:17 PM »
You don't have to split the case; the flywheel just bolts on. You can buy a custom aftermarket flywheel made by KEP or someone like that. Call Airspeed, if they can't get you one they can probably steer you in the right direction. Let us know what you find. I've considered this swap myself. A \"stock\" big bore motor. :D
Offline Rob DVKK
Engine&tranny
« Reply #4 on: February 25, 2006, 10:53:02 PM »
Had a 914 - 2.0 in my 54. Ran it for a few years, nice motor but the type I 1914 ran better times at the track. You don't really need a special flywheel. As long as you use the 210mm all you will really have to do is clearance the bell housing. I can't remember for sure, but I think I still used the same starter. What type of cooling are you going to use?
