Author Topic: Quick Questions  (Read 2655 times)
Quick Questions
« on: February 22, 2006, 08:48:14 PM »
My pulley has Three \"V\" marks. Every book I look has only two \"V\". Until I get a numbered pulley.
Are the \"V\" marks  \"0\", 5 degrees, and 7 degrees?
And as I look at it left of \"0\" is ATDC, and right of \"0\" is BTDC?
Emilio
Quick Questions
« Reply #1 on: February 22, 2006, 11:51:57 PM »
afaik they should be TDC, 7.5 degrees, and 10 degrees.
yes, you are correct.
Offline 68IIIbuggy
Quick Questions
« Reply #2 on: February 23, 2006, 08:31:23 PM »
If in doubt you can feel down #1 plug hole with a small screwdriver and slowly rotate engine back and forth to figure out exactly where TDC is.
