Author Topic: Help! Pedal Cluster Question..  (Read 1116 times)
« on: February 11, 2006, 01:13:53 PM »
Guys,
Last year I had my brakes fail when the clip holding the pushrod to the brake pedal flexed out. To fix it I ended up taking apart the clip striaghtening it and then wiring it into place. Today I found it flexing the clip out and having the pin pop out. I need a better solution or possibly new one.
If anyones willing to help me out today with this and pull the cluster and figure something out pm asap or post up. I need the car tommorow.
« Reply #1 on: February 11, 2006, 04:25:41 PM »
Iam confused. Is that you pedal assembly on you bug? Can you just do what you did before or, do you think you need to raplace it?
Emilio
