Author Topic: Bondo Removal  (Read 2077 times)
Offline 72vwtype2
  • Phil
Bondo Removal
« on: February 08, 2006, 08:26:31 PM »
I am about to start working on my engine deck lid and a fender. They both have a moderate amount of bondo on them. I believe once I remove the existing bondo I can smooth out the metal and use considerably less bondo. My questions are:
What is the best way to remove Bondo? Heat (Propane Torch), Sanding it out, Chemical (Aircraft) or Sand Blast?
Then once the bondo is removed, and before working the metal, should the bare metal be protected, such as etch primer?
Thanks.
1972 Kombi
1964 Vespa 150
Bondo Removal
« Reply #1 on: February 08, 2006, 09:38:36 PM »
Bigger hammer, It will take it right off........
Offline jason_hamilton
  • Admin
  • 1969 Karmann Ghia 2161cc
Bondo Removal
« Reply #2 on: February 08, 2006, 09:52:52 PM »
The last time I had to do it I got good results with Canadian Tire house-brand chemical stripper. It took at most two applications and some scraping to remove up to 1/4\" thick. A quick once-over with a wire brush to clean up and it looked like virgin metal.
Jason Hamilton
Offline dirtydeedss
Bondo Removal
« Reply #3 on: February 08, 2006, 11:57:52 PM »
fire always works good
Bondo Removal
« Reply #4 on: February 09, 2006, 09:44:45 AM »
heat gun works really well.
Bondo Removal
« Reply #5 on: February 09, 2006, 10:08:23 AM »
Thanks.
I like using a bondo buster or an angle sander. CAREFULL AROUND EDGES. If there is a fair amount of rust repair to be done, use an corrosion resistant etch primer then use DP 90 epoxy primer. Then put filler on that. If you need any more hints or guidance, pm me and I'll give you what I know
Jason
Offline rustybus
Bondo Removal
« Reply #6 on: February 09, 2006, 01:57:51 PM »
Thanks.
Jason
ya what he said :D
Offline blarneyman
Bondo Removal
« Reply #7 on: February 10, 2006, 05:47:18 PM »
I just used a wire wheel on my drill. Made a huge mess but worked great!
www.mbvv.org
My \"new\" 1970 Ghia
