Author Topic: Rust Problems (body/pan Seperation)  (Read 4202 times)
Offline Tyrel
« on: January 26, 2006, 01:18:16 PM »
well this morning i was taking out the bolts that hold the pan and body together, and 4 of the ones under the car that appear to go into the heater channel wont come out.  it sounds like a backing plate inside the channel is spining with the bolt?  will i be able to just lift the body and hope those pull through or is there a better solution?  now the heater channels must be shot so how hard is it to put new ones on??? im putting a 3\" bodt lift on this car if that makes any difference at all :P               thanks guys         Tyrel
« Reply #1 on: January 26, 2006, 08:05:23 PM »
Get in there with your angle grinder and grind the heads off.  Don't pull them through.
