Author Topic: Filler Neck, What To Do?  (Read 3105 times)
Offline nivag
  • Gavin Lee
« on: January 22, 2006, 07:37:27 AM »
Attached is a pic of my buggy, I want to clean up this butchered hole they cut to clear the filler neck. Problem is it does need a bit of play to be able to slide a bit as I lift the hood off. As I pull the hood off I need to tilt and slide it forward to remove. Main thing I want to do is seal that hole so if I am out in the rain it is not just pouring in there...
Anyone have any suggestions as to how I may be able to make this look better? Was thinking if there were some sort of rubber diaphrams or something I could attach to the body that seals the hole but stays tight around the filler neck??? Other thought is to section the filler neck itself, maybe cut it down 3-4\" so I don't need as clearance on that hole... Any suggestions welcome.
Gavin
« Reply #1 on: January 22, 2006, 09:36:50 AM »
Look into an RV shop. They will have finishing stuff for trailer homes or recreational boats. Heck you may even be able to find something at walmart.
Emilio
