Author Topic: Need Repairs Minor & Intermediate  (Read 1118 times)
« on: January 09, 2006, 06:48:47 PM »
I need to buy \"VWC-111-957-801-J   SPEEDOMETER CABLE, 1235MM - STANDARD BEETLE 46-77/GHIA 56-71 \"
and I can replace that.
I need loose weight and  re-weld my front seat mounts, I may be able to get a friend to do it but, I would like to know what would it cost if someone else does it?
I got a new oil pump and  a set of adjustable push rod tubes with the dounuts ( they could be installed without having to remove the heads, I believe.) and I need an estimate of what would it cost to do this and adjust the valves at the same time. Someone with experince (this car is not an experiment.)
Emilio
« Reply #1 on: January 16, 2006, 06:18:02 AM »
I need to buy "VWC-111-957-801-J   SPEEDOMETER CABLE, 1235MM - STANDARD BEETLE 46-77/GHIA 56-71 "
Emilio
We found out that the \"welding bits\" is more than bits. The person who installed the floor pans did not weld the tunel to them, he used some cocking  or something else,. My driver side track is all bent and basically I need to weld both sides of the tunel. and get a new track
While funding is an issue, I am also not looking at taking advantage of people on the site.
I like to get an idea of how much time this would take and what would is cost?
Emilio
« Reply #2 on: January 16, 2006, 07:21:33 AM »
pm double door on this forum,
also i think gutterslugs brother said he could do something like this.
i would assume both would be reasonable in price (i have used double door AKA: Darren and he was great)
« Reply #3 on: January 16, 2006, 08:09:34 AM »
Darren did a great job on my oil leak.
Emilio
