Technical
Chassis & Suspension Forum
Cb Beam And Adjuster Question
Topic: Cb Beam And Adjuster Question (Read 3390 times)
January 09, 2006, 08:34:14 AM »
i have a cb beam from airspeed.
i was wondering if i can adjust the adjusters independently?
i know i can physically but wondering if they should be kept the same top to bottom all the time when raising and lowering it?
James Buchan
January 09, 2006, 10:24:43 AM »
I would think adjusting them seperatly (at two different indexes) would put undue strain on one or the other spring pack - I don't think it's a good idea.
Lanny
January 09, 2006, 08:34:21 PM »
Origionally the set screw positions are slightly different from each other top to bottom. I usually tighten down the adjusters where the sit, rarely the same, top tube to bottom tube.
Technical
