Author Topic: Screen On Sump Is It Needed?  (Read 4370 times)
Offline BreakinSouls
« on: December 22, 2005, 05:11:33 PM »
Hey guys, I got a full flow oil pump and remote oil filter do I need to remove the screen filter from the bottom of the engine/ sump?
Live Life And Fear Nothing.
« Reply #1 on: December 22, 2005, 05:23:01 PM »
Yes, get rid of the screen. It only adds a restriction.
« Reply #2 on: December 22, 2005, 06:00:22 PM »
Thanks for the Info. :D
« Reply #3 on: December 23, 2005, 12:08:35 AM »
Leave it on.  The filter is after the pump, and if an errant nut or other broken bits gets sucked up, it will jamb the pump gears, reducing your oil pressure to zero faster than you can shut the engine off.
All cars have a screen over the pickup for this reason.  If you think it is a restriction, get a Brazilian one, the mesh is much bigger than the original one VW supplied with your car.
