Author Topic: Need Type 2 Hub Studs...  (Read 1331 times)
Offline Boost_Retard
« on: December 04, 2005, 06:41:23 PM »
My baja rear end consists of late type 2 drum hubs..spacers..rotors..huge ass adaptor plates..
i need a stud thats the same OD as a stock type 2 hub stud..the stuff you find on the 5x112 Van rear drum hub..im sure 3/4\" longer would be good..but 1\" longer might be better....i have allot of things that need to be stacked up on these studs..and they are going to get beat to $hit so they need to be high quality material..i need 10 of them and nuts.
i know this aint the right place to post but i figured i might get a fast responce..wich i need :)
i also need 10 type 1 style studs..not sure who makes them but my baja came with a nice set of heavy duty black studs with goldish lug nuts..they were pressed into the front drums...if i could find those they would work out great in my adaptors..
Airspeed?
thanks
Cale
« Reply #1 on: December 05, 2005, 09:25:39 AM »
Hey Buttercup, Give me a call...I have what you need.
Offline Custom76Bus
    • http://vw.norquaydesign.com
« Reply #2 on: December 06, 2005, 07:27:07 PM »
for my bus i had to buy aftermarket pressin studs with the same insert-diamter. Had to go to mopac and get some american threaded ones to fit. worked out alright it seems.
good luck... and wish i knew airspeed had em before  :rolleyes:
--Gavin
« Reply #3 on: December 06, 2005, 08:10:01 PM »
i got some from air speed...they LOOK close to the stock bus size spline...i need to get some actual #s though..
the stock bus stud has a finer spline then the empi peices...but they should work out..
the peices that air speed sells are the ticket..im 99% sure they will press into a stock bus hub without any drilling..
My hubs are at the machine shop right now..when they come back im gonna install the studs and i will let you know.
Cale
