Engine Tech Forum
Revs Dont Drop Fast Enough
Topic: Revs Dont Drop Fast Enough (Read 4634 times)
kit
November 19, 2005, 05:43:11 PM »
my revs dont drop fast enuogh, like they should i have a 009 dist, dual 40 kads, does anybody have any suggestions
68IIIbuggy
November 19, 2005, 06:00:45 PM »
Check for lean idle mixture/idle speed set too high.
kit
November 19, 2005, 06:16:27 PM »
set the carbs according to the directions, no smoke,and my idle is low , i was thinking something to do with the dwell, or the timing, but not sure or maybe i have a intake leak, ? not sure
68IIIbuggy
November 19, 2005, 08:36:56 PM »
Intake leak and idle mixture set too lean could both cause the same problem. Is your idle smooth and even? If so you probably don't have an intake leak. Set your timing at 7.5-10 deg btdc. Dwell should be 44-58 deg. Also make sure your throttle cable isn't hanging up-a common problem.
John W. Kelly
November 20, 2005, 12:03:20 AM »
Return spring force? Might need stronger ones.
kit
November 20, 2005, 12:50:21 AM »
i have returned the throttle by hand and this is not the problem, my spring is really good
kit
November 20, 2005, 09:21:25 AM »
well i think i found the problem, the spring on the advance was weak , the rotor wasnt snapping back hard enough
Engine Tech Forum
