Author Topic: Oil Sump Torque Spec  (Read 4779 times)
« on: November 14, 2005, 11:43:48 AM »
what should the oil sump be torqed down to?
thanks
« Reply #1 on: November 14, 2005, 11:49:28 AM »
i think its about 10 ftlbs
dont go too much more tho, cause those studs REALLY like to break
« Reply #2 on: November 14, 2005, 11:52:52 AM »
Which type of sump are you installing Russ?
« Reply #3 on: November 14, 2005, 12:03:47 PM »
For the plain steel one which bolts to the bottom of case I like about 7 ftlbs. Or basically turn on a short ratchet till the tendon below my wrist pops out.
Just basically \"Snug then a slight tug\"
« Reply #4 on: November 14, 2005, 12:13:22 PM »
empi 3.5qrt sump and i'm looking at the sump to the case specs
thanks
« Reply #5 on: November 14, 2005, 12:52:58 PM »
Before install I would suggest a flat edge across the plain to make sure it's true - I hade to massage my Thinline a tad.
« Reply #6 on: November 14, 2005, 10:12:04 PM »
Mr Bentley says 5 ftlbs.  Use loctite.  Check once a year.
Offline Tom H.
« Reply #7 on: November 15, 2005, 05:48:44 AM »
You don't have to worry aboot \"distorting the sump plate syndrome\" so I'd second the 10 in. lb.
