Author Topic: Bullet Front Fenders  (Read 1365 times)
Offline woodsy
« on: November 13, 2005, 01:26:11 PM »
Does the early bullet style front fenders fit on a 65 ?
Offline slugbug
« Reply #1 on: November 13, 2005, 01:44:52 PM »
They will fit up to '66. The only problem you might have is the headlight wire tubes on the bullet fenders. not lining up with the holes on the 65. Easy fix.
[/a]
« Reply #2 on: November 13, 2005, 06:27:20 PM »
slugbug is correct cut the tube's off(yikes)
and they will fit
Offline ehos
« Reply #3 on: November 13, 2005, 07:15:11 PM »
I don't think you have to cut the wire tubes.  You can get away with bending them away from the body.  It's a hack, but not as bad as cutting the tubes!
