Author Topic: Anybody Know This  (Read 6909 times)
Offline kit
Anybody Know This
« on: November 10, 2005, 10:29:40 PM »
well i decided to rebiuld my calipers,  who has done this , need to know how to get the pistons out, ?   two part caliper
Anybody Know This
« Reply #1 on: November 11, 2005, 01:22:07 PM »
well that will depend on the caliper. If it's a Beetle/Ghia front caliper you can use compressed air. Before spliting the caliper put your air nozzel into the hole where the line threads in, give a quick burst of air and they will push out and touch each other. If it's apart you can do the same thing but you will need to block the two holes that feed the other caliper half. Beware!!!! if it's apart the piston can shoot out like a bullet! I have dents in the roof and broken light bulbs to prove it.
Offline kit
Anybody Know This
« Reply #2 on: November 11, 2005, 05:38:29 PM »
so i have to get a threaded end for my air hose to the caliper
« Last Edit: November 11, 2005, 05:38:54 PM by kit »
Anybody Know This
« Reply #3 on: November 11, 2005, 07:25:55 PM »
usually just a rubber nozzle will do
Offline kit
Anybody Know This
« Reply #4 on: November 12, 2005, 04:59:06 PM »
well the calipers were siezed, took 135 psi for two hours to get them unstuck,  all done everything worked just fine , thanks again
