Author Topic: Removal Of Undercoating  (Read 1435 times)
Offline Mike Scott
« on: November 10, 2005, 08:50:50 PM »
Anybody have any tips for removing 40 year undercoating from inner fender wells and inside of fenders?
I want to clean up and re-spray semi-gloss black.
« Reply #1 on: November 10, 2005, 09:02:58 PM »
Aircraft paint stripper, scraper and a wire brush. HAVE FUN!!!!
Offline rustybus
« Reply #2 on: November 10, 2005, 09:19:21 PM »
Air chisel :D
« Reply #3 on: November 10, 2005, 10:20:25 PM »
Use a heat gun and a scraper. It's a terrible job, but this is the method we had the most success with. :wacko:
« Last Edit: November 10, 2005, 10:20:50 PM by vwboop »
« Reply #4 on: November 11, 2005, 12:58:38 AM »
2\" putty knife & a small hand held propane torch.
heat the area in front of, but not directly on, the putty knife. dont heat it up too much or it turns to goo. use the putty knife to follow the trail of the previously heated area.
this is the method i used on the pans and fenders on my 56. it took a little practice to dial in the proper technique, but it ended up working fairly well.
also, watch the amount of heat or the paint on the other side of the fender will bubble.
good luck mike.
Offline Mike Scott
« Reply #5 on: November 11, 2005, 10:17:49 AM »
Thanks guys,
I almost discovered the heat method myself last night. I tried the wire wheel on a 4\" girder and it made a huge mess, but the area around (heated area) came off quite easily. 1 wheel well down, 3 to go and 4 inner fenders.
Mike
Offline kit
« Reply #6 on: November 11, 2005, 10:38:23 AM »
there is atool for this you can buy from kms, it is called a descaler, it is a air tool with pins on the end , it works great , just did 2   55  chevys , with realy bad undercoating
