Air Speed Lounge
Any Body Know This
Topic: Any Body Know This (Read 1298 times)
kit
Any Body Know This
November 09, 2005, 01:50:53 PM »
should this pump run constant or intermitant according to the heater
kit
Any Body Know This
November 09, 2005, 03:05:35 PM »
well i think i know, the pump runs off a points system on the heater fan shaft, wich in turn sends a signal to the pump metering how much fuel is sent to the heater, can anybody confirm this?
pockets
Any Body Know This
November 09, 2005, 03:37:31 PM »
the pump runs intermitantly (sp?) it should not run steady
Any ideas on how to wire up a P1502 gas heater that mounts above the transmission?
When my electrician was checking the parts I have he told me about the pump
Ubique
1968 bug
Bruce
Any Body Know This
November 09, 2005, 08:43:27 PM »
Are you talking about a remote pump under the gas tank for a late BN-2, or the pump mounted on the heater for an early BN-2 or B-2?
kit
Any Body Know This
November 09, 2005, 09:48:04 PM »
the pump under the tank
BUSDADDY
Any Body Know This
November 10, 2005, 06:42:47 AM »
Late BN-2 metering pumps (Remote mounted) should tick every 2-3 seconds continuously when connected to the timing points in the heater (heater fan running). Should only tick once every time the power is applied on the bench. As for testing it needs to be wired to the heater and have a hose run to a graduated container and amount of fuel measured after the time specd. in the manual. Hope this helps.
pockets
Any Body Know This
November 10, 2005, 09:15:36 AM »
check type-14.com under chassis
Ubique
1968 bug
Air Speed Lounge
Any Body Know This
