Author Topic: Bruce, Wanna Cross Drill My Rotors?  (Read 6676 times)
Offline Boost_Retard
« on: November 05, 2005, 10:07:44 AM »
If there is anyone that can cross drill a set of italian 73-79 type 2 front rotors for me, please let me know.
send me a PM or please reply to this post..
i will give you a call and drop them off.
thanks
Cale
« Reply #1 on: November 05, 2005, 12:06:29 PM »
Do the rotors have radial vents?  What is the OD of the rotor?  ID?
My template fits KG/Type3/Porsche 914 rear rotors.
« Reply #2 on: November 05, 2005, 03:03:05 PM »
the rotor is a brembo 73-79 type 2 front rotor, it has 11\" OD 5X112 bolt pattern
i have no means of measuring the thickness of the rotor..or the ID at the moment..but then minimum thickness is 11mm..so im guessing its around 12mm..
when i get the actually #s i will post them
Cale
« Reply #3 on: November 05, 2005, 09:51:37 PM »
Since it is 12mm thick, that means it is solid.  Since it is solid, I can drill it.  All I have to do is make sure my template will work.
