Author Topic: Trailing Arm Slop  (Read 3430 times)
Offline mike
Trailing Arm Slop
« on: November 04, 2005, 09:48:19 AM »
Hey guys,
I'm just fitting my trailing arms into my new narrowed K/L beam with needle bearings and they don't fit quite snug. When fully inserted, the arm has play in it when moving the arm vertically. These arms originally came out of a micarta bearing beam. Are there two different types of trialing arms for each type of bearing?
I measured my trailing arms and they came to a spec range of 36.87mm - 36.91mm. my guesstimate would be if these were about .4mm larger in diameter they would fit without any play.
Even thought it seems like it will work, I
