Author Topic: Have A Alighn Set ,know How Do You Use It  (Read 4036 times)
« on: October 25, 2005, 06:28:08 PM »
i have this vw align bore set for vw cases and want to set it up for boring my crank case back to stock ,seems at the case parting surface i'm .002 below vw min spec on my #1 bearing bore.i figured out how to set the cutters as well as ounting it in the case ,but what drives this thing.there is a attachment that hooks into a drill but not sure were it mount to the bar .as well as not sure what drives the boring bar in and out.if anyone has seen this used before please post here .i figure it will be great to have a main bore set -up for stock dimension locally.
« Reply #1 on: October 25, 2005, 07:50:58 PM »
OK it's been a long LONG time but it looks like you have everything there.  The big unit that fits into the flywheel seal bore, is the feed.  I just can't remember if you put your drill(allen bit?) onto it , or the bar it self at the pulley end? or what the fisical connection is between the feed unit and the bar. If I had it in my hands I could probably remember.
« Reply #2 on: October 25, 2005, 09:28:48 PM »
Darren K has the same one as do I. I havent used one in 7-8 years. I know Darren can walk you thru it. The main thing is to have a bar set up fot 1st,2nd and 3rd cut so you dont have to keep changing or adjusting the cutters. Practice on a old case ;)
Looks like you have the thrust cutter as well.
« Reply #3 on: October 25, 2005, 10:04:12 PM »
well after looking at it for a bit i finnally realised i have parts from 2 sets.so here i was trying to figure how the whole thing bolted together not realising i did not need all the parts.
then vola!!! LIFT THE FOAM PAD and the instructions are there!!
now i get it.
ok now i need some junk cases to practice on and set bar up.
thanks bruce .you gave me the idea a long time ago about sending my case to rimco as they have a std bar setupto bore  and seams thats what needs to be done.
#4/#3 are great #2 is less than .001 out but #1 is undersized
