Author Topic: Mounting Engine  (Read 3824 times)
Mounting Engine
« on: October 17, 2005, 07:08:12 PM »
stupid question but when mounting the engine on the engine stand the studs come out the bottom do you remove the studs and just run a short bolt into them.or do you just put a sleeve over it and tighten it on.
the arms do not line up for the top holes.
thanks russ
Mounting Engine
« Reply #1 on: October 17, 2005, 07:16:30 PM »
Use the upper and lower mounts on the same side of the engine - for the stud I put some over size nuts inbetween as spaces to make it snug up.
Mounting Engine
« Reply #2 on: October 23, 2005, 11:38:09 AM »
I cut a piece of SS tube for a spacer.
