Author Topic: How Do You Wire A Gas Heater Type Three  (Read 1964 times)
Offline kit
« on: October 09, 2005, 11:06:33 PM »
who can give me detailed instructions for a stock gas heater, on a 1972 fastback, basicaly i have the heater and i know where it goes , i dont know about the electrical, five wires coming out to a plug, beyond that i dont know where the wires lead to, and i dont know where the gas line comes and goes from, can any body help with this?
« Reply #1 on: October 10, 2005, 08:16:07 AM »
Find a wiring diagram. Online there are a few.....someone should chime in with some addresses.
« Reply #2 on: October 10, 2005, 08:54:20 AM »
www.vintagebus.com has the best online diagrams - otherwise goto Airspeed and pick up a bentley manual.
Offline Tom H.
« Reply #3 on: October 10, 2005, 09:00:59 AM »
Bruce Tweedle has a manual for BN2s and can help ya out, most likely
« Reply #4 on: October 10, 2005, 10:13:13 AM »
For the later 5 wire bn2 heaters it's,
Brown wire to ground,
fat green or maybe blue ( I'll have to check, memory fuzzy) to battery with inline fuse (16a),
gray wire to dash switch +,
two smaller wires left over go to the fuel pump. ( neg. should have some brown on it)
You got a fuel pump right? it's usually on the front bulkhead below the tank in front of the passengers footrest, early 3 wire heaters have it mounted on the heater but it's a different pump.
Hope this helps, I'll go look today and get the exact colors for you.
Offline jason_hamilton
  • Admin
  • 1969 Karmann Ghia 2161cc
« Reply #5 on: October 10, 2005, 10:19:30 AM »
There should be a plate on the heater housing stating what model of heater it is. My Karmann Ghia website (www.type-14.com) has detailed factory manuals for the BA4, BN2 and BN4 model gas heaters on the \"Chassis\" page.
Jason Hamilton
« Reply #6 on: October 10, 2005, 11:02:51 AM »
Ok, I've got a great memory, it's just short. That was for the pre 72 heater. Just went and looked at a 72 and up 5 wire BN2 and it's...
Red/white = Battery + 16 amp fuse
Brown = chassis ground
Blue = dash switch +
Green = Fuel pump +
Brown/white = Fuel pump -
Late style metering pump (push on fittings on opposite ends, looks like a long fuel filter with wires coming out) mounts under the fuel tank and tees into main fuel line, 1/4\" line in, 3/16\" line out to burner nozzle on heater.
Good luck.
