Author Topic: Spark Plug Question  (Read 8883 times)
Offline JSimmons
Spark Plug Question
« on: November 17, 2003, 06:48:14 PM »
Aloha,
In another thread on engine storage, I asked for some suggestions as to what I should do.  Someone recommended spark plug desiccants from Eastwood Co.  So, which ones should I buy for the VW head?  14mm or 18mm?
Here's the link:  Eastwood Engine Desiccants
I should know this...
aloha,
Joel
Beer is proof that God loves us and wants us to be happy.  ~Benjamin Franklin
Spark Plug Question
« Reply #1 on: November 17, 2003, 06:57:53 PM »
Mine are 12mm - CB 044's
Offline AlanU
Spark Plug Question
« Reply #2 on: November 18, 2003, 10:47:46 AM »
I thought I've seen it all!! I'd pull the plugs and spray wd40 in the cylinders so that it'll have a light coating of oil to prevent rust.
some people will even get the oil can and squirt in there but at least with wd40 you can cover a larger surface area within.
Dessicant is an interesting idea but once in gets saturated with moisture it wont be able to absorb any more. If you buy a can of wd40 it'll cost you $3.00?? vs. $32. While your at it remove the rocker shafts so you dont keep the valve springs compressed over a long period of time.
14mm for the older CB heads, stock and many other aftermarket  head but lately the newer cb heads use the motorcycle 12mmm plugs.
« Last Edit: November 18, 2003, 10:49:28 AM by AlanU »
Offline JSimmons
Spark Plug Question
« Reply #3 on: November 18, 2003, 05:22:18 PM »
Aloha,
Hmmm...I like WD40 at $3/can.  Thanks for the info on the plugs.  Mine are welded German heads.
~Joel
