Author Topic: Just Installed 2" Lowered Beam....problems?  (Read 3641 times)
Offline BreakinSouls
« on: September 20, 2005, 01:42:03 AM »
If anyone can help it would be great.
I just installed a 2\" lowered beam, new ball lowered ball joints, new tie rod end and now the steering feels like something is dragging or binding ( It turn smooth before the work was done), Also the steering doesn't return after going around a corner?
I couldn't mount the steering box on the the two notches on the beam because it put the steering coupler at a really bad angle.
Live Life And Fear Nothing.
« Reply #1 on: September 20, 2005, 05:53:30 AM »
you need an alignment.
Offline HeliMike
« Reply #2 on: September 20, 2005, 08:27:13 AM »
Call Dales Alignment since you live in Langley. They're good shit  :rockon:
67 Sunroof Beetle
« Reply #3 on: September 20, 2005, 07:30:12 PM »
ditto on the alignment.
did you install caster shims?
how did you set the toe?
« Reply #4 on: September 21, 2005, 12:32:59 AM »
I did the alignment at work, I set the toe and camber but I did know there are caster shims. That would make a difference.
I'm thinking I may have buggered one of the ball joints when I pressed them in. But I'll check my alignment numbers again.
thanks
