Author Topic: Need Scan Of F7 Emulsion Tubes  (Read 4080 times)
« on: September 19, 2005, 03:56:46 PM »
a odd request but,working on something and if someone has there carbs apart or has some extra           emulsion tubes f7's in a spare box .wondering if you could scan them from a  2 sides as i need to look at hole placement and dimensions
Offline John W. Kelly
« Reply #1 on: September 27, 2005, 09:40:25 PM »
Best I can do is give you the dimensions of the tube such as ID, OD, size and locations of the holes once I get going tomorrow.
« Reply #2 on: September 27, 2005, 10:34:55 PM »
that would be great ,i was already sent a scaned photo [thanks!!!!]the added info on dimensions etc would be great
Offline Bubba
« Reply #3 on: September 28, 2005, 08:28:13 PM »
Hey buddy, you should have asked!  I could have put sections under the microscope and digitally measured whatever you wanted!
Csaba
64 Beetle
86 Nissan Multi
81 Rabbit
90 Malibu Euro F3
94 H-D FXDWG
« Reply #4 on: September 28, 2005, 09:21:25 PM »
Weber part # 61450.91; outer diameter: 7.5mm, inner dia.: 3mm, the lowest set of holes (4 holes, each one is 2.5mm) are 7mm from the bottom of the tube however the tube reduces is outer dia. to 6mm directly above the holes for about 12mm from where the holes start. Next set of holes are 19mm from the bottom of the tube and are 1mm times 4. The next set of holes are 28mm from the bottom and are 8 in number and are 1mm each. Overall length is 50mm. Got all that? Now go grab a beer! :wacko:
« Last Edit: September 29, 2005, 07:28:11 AM by John W. Kelly »
