Technical
Transmission Forum
Hydraulic Clutch's
Topic: Hydraulic Clutch's (Read 5555 times)
Hydraulic Clutch's
September 16, 2005, 11:03:24 PM »
How do these install and how exactly do they work? Is the clutch/pressure plate still the same or does that need to be changed with the kit? I need to custom make a clutch cable for the new project, and thought this may be an option.
Chris
Car.
Hydraulic Clutch's
September 16, 2005, 11:14:33 PM »
As I understand its a direct replacement for the clutch cable, maybe send Hoosier a PM he installed one in his squareback.
dannyboy
Hydraulic Clutch's
September 16, 2005, 11:14:34 PM »
dont need to change the pressure plate, the only thing i think you need to do is fab a mount for the master cylinder at the front...
the slave is a bolt on i believe
Hoosier Daddy
Hydraulic Clutch's
September 19, 2005, 08:03:04 AM »
I did it in the Square. Total bolt in kit, no fabbing, blead it once and forgot about it.
Technical
Transmission Forum
Hydraulic Clutch's
