66' Fenders?
Topic: 66' Fenders? (Read 5045 times)
BreakinSouls
66' Fenders?
August 28, 2005, 11:04:04 PM »
This might be a dumb Question, but can anyone tell me if 66' front fenders will fit on a 68' Bug?
Live Life And Fear Nothing.
66' Fenders?
August 28, 2005, 11:22:57 PM »
The fenders themselves will bolt on, but you will need to cut a hole in them for the bumper brackets, and install different H/L assy's
James Buchan
66' Fenders?
August 29, 2005, 06:22:45 AM »
Turn signals are different as well - on the 68 up fender your signal resides ontop of the fender. 66 down fenders they are in the headlight assembly and the light ontop is a marker - so some wiring will need to be changed up.
slammedbus
66' Fenders?
August 29, 2005, 07:42:03 AM »
If you plan on changing to an older hood you will need to change the front apron too.
jason_hamilton
Admin
1969 Karmann Ghia 2161cc
66' Fenders?
August 29, 2005, 01:26:20 PM »
smoking something james?
inside headlight is a marker, on top is turn signal
Jason Hamilton
dannyboy
66' Fenders?
August 29, 2005, 01:28:43 PM »
whoops /\
that was me |
James Buchan
66' Fenders?
August 29, 2005, 01:46:40 PM »
OOPS MY BAD :blush:
66' Fenders?
Reply #7 on:
August 29, 2005, 05:44:56 PM »
Unless of course James did his own wiring. Then the high-beam acts as the signal, and the marker as the brake light.
James Buchan
66' Fenders?
Reply #8 on:
August 29, 2005, 06:39:28 PM »
BUSTED! Damn meddling kids!
BreakinSouls
66' Fenders?
Reply #9 on:
August 29, 2005, 09:29:15 PM »
Cool thank for the input, I want to run 66' fenders and the porsche headlight with the signal in the lamp assembly.
looks cleaner
BreakinSouls
66' Fenders?
Reply #10 on:
August 30, 2005, 11:46:07 PM »
Is there a specific year fender that doesn't have the holes in the top for the signals ie pre-66'
Russ
66' Fenders?
Reply #11 on:
August 31, 2005, 07:20:21 AM »
early 55 fenders don't have the turn signal on top (any semaphored car actually)
but the price would be rather steep i would think for a set.
Russ
bwaz
66' Fenders?
Reply #12 on:
August 31, 2005, 11:26:46 AM »
It might be less visible if you had a set of Bullett signal fenders if you had to full them in. (55-57)
B
66' Fenders?
