Author Topic: The 63 Standard  (Read 10551 times)
Offline reefreshd_jive
The 63 Standard
« on: August 27, 2005, 04:32:38 PM »
hey everyone,
just got in from picking up my 63 from victoria. it turns out that it is a standard beetle! it is solid rust free. just needs to be sanded, and painted. then it is ready to be wired and put on a pan.
keep you updated as i go, and will take more pics when i clean up the garage to give myself more space.
The 63 Standard
« Reply #1 on: August 27, 2005, 04:35:50 PM »
I hope you didn't wash my truck! It's a Ford - it needs the dirt to hold it together!
Offline rustybus
The 63 Standard
« Reply #2 on: August 27, 2005, 04:58:42 PM »
:o holy crap that looks clean
Offline dannyboy
The 63 Standard
« Reply #3 on: August 27, 2005, 06:14:14 PM »
i took a look when james brought it by the shop today, and its REALLY clean
what a steal!
The 63 Standard
« Reply #4 on: August 28, 2005, 12:06:12 PM »
here are some more pics of the car.
Offline Needles
The 63 Standard
« Reply #5 on: August 28, 2005, 01:27:35 PM »
Very nice...
The 63 Standard
« Reply #6 on: November 26, 2005, 06:21:06 PM »
well. it has almost been 4 months now, and i have made alot of progress. the body work is done and now painted thanks to chris(rustybus) for the advice and lots of help! the pan was cleaned up, and painted with tremclad rust paint. with the help of chris(1976bus) and james buchan we put on a ron lumus 1.5 inch tranny raise. i installed the rear discs, and are now being re-drilled to 5x100 bolt pattern. the body and pan have been mated, installed hood mounts, and ran the electric fuel pump. today nov. 26, i bought a motor for the car. its a 1776 with 40 dellortos, and full flow oil system. have to get the tin blasted, and painted then it is good to go. also have to weld in the new engine compartment. since i am using the tranny raise, i have to raise the side shelves so the line up with the cylinder tin! after that is done it is just assembly and buying all the small shit like hood release stuff, door handle and crank, etc, and all my seals. hope to be done now by mid febuary!
-body on pan
-rear discs, and cleaned up pan
-the new motor-tin to be blasted and repainted!
-cut out engine compartment to prep for new shelves that are raised
-scat procars to be re-upholstered
« Last Edit: November 26, 2005, 06:24:01 PM by reefreshd_jive »
The 63 Standard
« Reply #7 on: November 26, 2005, 10:30:03 PM »
:rockon:  :rockon:
The 63 Standard
« Reply #8 on: December 28, 2005, 12:50:15 PM »
I have to come in here more often alot of you guys have been really pounding through some projects looking great will check back  :)
The 63 Standard
« Reply #9 on: January 02, 2006, 07:54:10 PM »
well it has been been just over 4 months now since i brought the car home from victoria. i have been working away at it with all the spare time i have. since the last update i have been able to weld the engine compartment back in, i have the discs back from the machinist and on the car, the wiring harness has been pulled through, the motor has been assembled, and the exhaust has been made aswell.
here are some pictures...
Offline rustybus
The 63 Standard
« Reply #10 on: January 28, 2006, 09:41:33 PM »
you sould fill in those pee shooter cut outs :lol:  :lol:  :lol:  :lol:  :lol:  :lol:
Offline Stevie
The 63 Standard
« Reply #11 on: February 17, 2006, 09:42:43 AM »
any progress being made?
wouldn't mind a few wheels on the car and car on the ground pics
20's SORTA FIT!!
63 Beetle
The 63 Standard
« Reply #12 on: May 04, 2006, 09:06:10 PM »
well everyone, it had been a while since an update...
i am almost done the 63. after 8 months it is coming to an end. just have to tune the motor, put in the door windows, door panels, and the headliner.
Offline Klaatu
    • http://www.airspeedparts.com
The 63 Standard
« Reply #13 on: May 04, 2006, 10:14:59 PM »
Looks killer James!.......must feel good to finally have it on the road.  When are u going to lower it. :o   Did u get those valves adjusted?
I can't reach the bottom but I sure bang the sh*t out of the sides....
The 63 Standard
« Reply #14 on: May 04, 2006, 10:27:18 PM »
God damn that thing is mean.
Am I going to see it sunday?
Offline Mike Scott
The 63 Standard
« Reply #15 on: May 05, 2006, 08:56:25 AM »
Looks great James, its come a long ways!!!
The 63 Standard
« Reply #16 on: May 05, 2006, 06:16:34 PM »
That looks awesome James!! I can't beleive you didn't keep the mint green engine tin though.
Offline Bullyboy
The 63 Standard
« Reply #17 on: May 05, 2006, 09:56:07 PM »
It looks like you might get a little more life out of a set of tires.
 I wish mine was that far along.
The 63 Standard
« Reply #18 on: May 06, 2006, 04:30:57 PM »
good work james.
i saw pics on thesamba.com and i was wondering when you were going to post an update.
Offline rustybus
The 63 Standard
« Reply #19 on: May 06, 2006, 10:08:57 PM »
killer :rockon:
Offline beetleboy
Re: The 63 Standard
« Reply #20 on: October 16, 2009, 12:32:18 AM »
HEY!!!!.....I recognize the pea shooter holes
