Author Topic: Choke Cable Wont Come Out  (Read 3577 times)
« on: November 10, 2003, 06:58:15 PM »
is there a trick to getting the choke cable out? 56 chassis, completely stripped and ready to blast & prime, but the choke cable seems to be stuck in the tunnel. i pulled from the back and pulled from the front but it wont budge.
i wont be needing it so i could just clip the ends off, but if anyone knows how to get it out, please let me know.
cheers
« Reply #1 on: November 24, 2003, 06:18:45 PM »
did you ever get the cable out?
i'm sure mine was full of lube when i pulled it out(it came out by pulling no problems)
if is really stuck mabey try a little lube to loosen it up
russ
« Reply #2 on: November 25, 2003, 11:16:33 AM »
thanks russ, that's a good idea, i'll try the lube
i know it hasn't been used for the 5 years that i've had the car, so it's probably just jammed from lack of use.
