Author Topic: Billys Monster Garage  (Read 1104 times)
« on: August 12, 2005, 09:45:41 PM »
Well just put in 4 hours at billys place motor looks good ,still some pluming do do . Got started on plexi windows . I'll say one thing it is going to be tight but he sure has been doing alot of work congrats to you kevin . It may be rough but will be improved as he gets time later . Good lucck kevin talk to you this week and thanks for not yelling at your helper
Later outkast
« Reply #1 on: August 12, 2005, 10:19:48 PM »
Yes thankyou for the help.  I was a little disapointed after spending 5 hours at the glass shop with the old guy painstakingly trying to cut my glass, only to find out that the window is now curved, and the glass had to be cut in the middle.  And then installing it finding out it was to small, and didn't fit in the opening right.  And then it cracked.  It cost $80.00 for all this time.  And I am going to use Lexan instead.
It was a breath of fresh air to have you over Marty, who cares if the glass window and the lexan cracked, we  got some things done.  The Lexan was free ( thanks Shane) , so it makes a good template now for the real thing.
The engine has to be in by Sunday night ...I hope so.  Hopefully I can track down some more argon.
« Reply #2 on: August 12, 2005, 10:27:20 PM »
good job, kevin.
hope to see you racing at mission.  B)
Offline Mike Scott
« Reply #3 on: August 12, 2005, 11:42:30 PM »
Sounds like your making progress......good luck Kevin!
