Author Topic: Parts Blow Out Extravangza!  (Read 3206 times)
« on: November 05, 2003, 03:45:40 PM »
Alright guys..
Just got my interior quote back.. Need less to say its a lot more then I thought it would be.. hmm how about 3 times!?
Anyways.. Thats what you get when you use Mahogany backing and Imported vinyl.
Anyways stuff has to go..
ASAP
Cutting brake for a Baja/Buggy. Has seized cylinders.. housing in good shape vintage. Needs new boots and obviously the cylinder thing worked out.
50$
40hp fan shroud with freshair ducts shaved off. Otherwise fanshroud is in decent shape. Comes with... 6 volt generator and voltage regulator. Genny looks like to be in decent shape. Rebuildable..
80 bucks
New (never used) 6 volt regulator. Bosch... 60 bucks.
German dual port heads. Has had work done to them Not exactly sure what. No cracks or facked fins. Beadblasted and has most of the guides installed. Comes with valves and springs.
250.
Brand new set of Kadrons Comes with steel dual port manifolds.
300$ Clean set of carbs never been used.
I have a bunch of NOS bearings and stuff. (engine wise) Willing to let it go quite cheaply. P-mail me with your needs.
I have more at home.. will list.
