Technical
Transmission Forum
Clearancing For 12v Flywheel
Topic: Clearancing For 12v Flywheel (Read 5926 times)
Mike Scott
July 11, 2005, 09:20:57 AM »
Does anybody have any pictures of a clearanced 6V tranny for a 12V flywheel? Where do you take the material from?
Mike
Trevor P
July 11, 2005, 11:20:31 AM »
Do you have a 12V flywheel handy? Use it to size up how much you need to remove from the bellhousing. The areas at 8, 4, 10, and 2 o' clock are the areas that intefere the most.
josh
July 11, 2005, 11:54:12 AM »
I've got my motor out and was just looking at the bellhousing last night thinking what a quick hack job I did on mine. It's mostly the bulges that the engine bolts come through that you have to shave down. Ill take a pic tonight and try and post it (haven't had much luck with pic's) Don't forget to put in a 12v starter pinion locating bushing and red loctite it in.
Mike Scott
July 11, 2005, 01:01:41 PM »
Thanks Guys,
I actually do have a spare 12V flywheel handy, never thought to just do a test fit. Try that out tonight.
josh
July 11, 2005, 09:21:09 PM »
took some pic's but can't post
sorry man
Technical
Transmission Forum
