Author Topic: Spark Plugs  (Read 4032 times)
Offline flat4
Spark Plugs
« on: July 08, 2005, 11:43:58 AM »
I removed my plugs last night to find out that one of the electrodes is burnt away.  Any suggestions for plugs?   Heads are CB Super Mags (long skinny plugs).  What gap should be used?
Water is for ducks
1975 Super Phat Chick
Sand Rail Project
Spark Plugs
« Reply #1 on: July 08, 2005, 11:54:06 AM »
WHat was in there? I run a W8 12mm plug with my 044's - seems to be the standard...
What gap do you run? Stock is .027 (give or take a few) with My MSD I am able to run a larger gap... maybe you were to tight?
« Last Edit: July 08, 2005, 11:55:13 AM by James Buchan »
Offline flat4
Spark Plugs
« Reply #2 on: July 08, 2005, 12:09:10 PM »
I was running w7 plugs.  I couldn't tell you the gap right now.  Where should it be?  Stock or close to stock?
Water is for ducks
Sand Rail Project
