Author Topic: Fenders  (Read 5592 times)
Offline PBrusse
  • Junior Member
Fenders
« on: July 05, 2005, 12:28:57 PM »
I was dreaming about building a fenderless bug with a beam extension much like those seen on Volksrod.  Is that legal in BC?  Any positive feed back is appreciated.
Thanks, Philip
Fenders
« Reply #1 on: July 05, 2005, 12:39:14 PM »
Offline PBrusse
  • Junior Member
Fenders
« Reply #2 on: July 05, 2005, 12:45:38 PM »
Thanks, I've been there.
Fenders
« Reply #3 on: July 05, 2005, 01:18:18 PM »
esentially the answer is no its not legal, you are required to run fenders and /or all body panels your vehicle was initally equipped with, but if it looks good I doubt it will be an issue, but if you build a shitbox then someone is likely to send you for an inspection, this is from what I recall from a previous time that I looked up the info.
Fenders
« Reply #4 on: July 05, 2005, 01:53:33 PM »
In some areas there is a sunny day clause that allows you to drive open wheeled vehicles on clear days.
Fenders
« Reply #5 on: July 05, 2005, 02:08:09 PM »
I saw a fenderless bug running around Maple Ditch the other day :rockon:
Fenders
« Reply #6 on: July 05, 2005, 04:35:08 PM »
that was cale, he probably cut his fenders off to save weight!
Offline thrasherbill
Fenders
« Reply #7 on: July 05, 2005, 05:03:10 PM »
I have talked to a few police officers about this. Technically you can not \"legally\" run without fenders in BC. If you only drive on dry days and the car doesn't look like a death trap then you probably won't get bothered. As long as the car looks \"done\" or close enough to it and looks safe you are probably OK. This is all up to the discretion of the officer that sees you. If he wants to be a dick you can get ticketed/ordered for inspection (which you won't pass without fenders).
ThrasheR
CLICK.
Pinhead Lounge
