Author Topic: Fuel Pump With Fi  (Read 3913 times)
Offline Bart
  • Junior Member
Fuel Pump With Fi
« on: July 04, 2005, 10:59:03 AM »
Can anyone tell me exactly what lines go where on an electronic fuel pump in a 77 FI bug?
Fuel Pump With Fi
« Reply #1 on: July 04, 2005, 06:01:02 PM »
Well , my bentey says power from terminal 88d of the double relays and ground at the head light ground terminal. Hope that helps.
edit
Ooppps , you mean fuel lines. Large dia. end to the main tank fitting . Small end to the injectors. Return line from presure regulater to return fitting on tank.
« Last Edit: July 04, 2005, 06:07:26 PM by Hansk »
