Author Topic: Long Wheel Studs  (Read 1077 times)
Offline Mike Scott
Long Wheel Studs
« on: June 21, 2005, 09:23:43 AM »
I've got an issue with my front rims. The clearance from the inside lip to the control arm when turning is a problem with my new disks, but I like where the wheels sit. Im was planning to narrow the beam 2\" then space the wheels off the rotors 3/4\" to an 1\" . Any comments? Anyone know where I can get longer wheel studs? they are the thicker (14mm??) porsche and bus type studs.
Thanks for any info
Mike
Offline hellgti
Long Wheel Studs
« Reply #1 on: June 21, 2005, 01:48:10 PM »
if your going that thick, the spacers should bolt to the disk and then the rim bolts to the spacer.  otherwise, running longer studs might not be the safest.
i may be going to a porsche rim setup on the GTI with H&R adapters, maybe we can get a bit better deal if you want a set of their spacers??
« Last Edit: June 21, 2005, 01:49:54 PM by hellgti »
