Author Topic: Ball Joint Or Kingpin?  (Read 3686 times)
Offline Mowser
« on: June 16, 2005, 08:57:02 PM »
What year was the first of the Ball joint front end in the Type 1?  Also was it a transition year where they had both like so many other things.  The deluxes get the new the standards get the old?
« Reply #1 on: June 16, 2005, 09:06:50 PM »
1966. but I have heard of some late in the year production 65's with it.
Offline Mowser
« Reply #2 on: June 16, 2005, 09:19:42 PM »
Thanks Matt... that's what I thought but wasn't 100%.  If '65 was the oddball year I should be off to the races.  Found a front end off a '66 but haven't seen it in person yet.
« Reply #3 on: June 16, 2005, 09:28:01 PM »
Keep in mind the bulkhead between the two is different. If your 65 has a kingpin front end you won't be able to just bolt up a ball joint.
Offline Mowser
« Reply #4 on: June 16, 2005, 10:05:18 PM »
Thanks  Matt.  Knew that already but I appreciate the knowledge.  Would that piss a guy off not knowing.  I'm looking into a new floor as well.  As much as I'd like to keep the og floor an upgrade is inevitable.  Likely a '68 or perhaps the matching '66 pan to go with the front end.  We'll see how the ball bounces.  Having another pan will give me the ability to keep driving while I do the repairs and changes to the donor. B)
