Author Topic: Best Trans For '64 With 12v 1600?  (Read 3635 times)
Offline Splinter
    • 64 Van Restoration
« on: June 04, 2005, 02:08:40 PM »
Does anyone know if I can use a 12V bus trans in my '64 without any modifications?
The engine is a 12V so the flywheel doesn't fit in the original one. I ground it out to make it work but now the trans pops out of 2nd so I want to replace it.
What years will fit??
-= 1964 Bus =-
« Reply #1 on: June 05, 2005, 02:25:35 PM »
Should fit fine in your Bus.
« Last Edit: June 05, 2005, 02:27:58 PM by Bruce »
Offline Splinter
« Reply #2 on: June 06, 2005, 08:11:24 PM »
Thanks for the info.
I found another member with a 6V trans already ground out but the wrong reduction boxes. He says they are interchangable so I guess I'll go that way.
-= 1964 Bus =-
