Author Topic: Pan Switch  (Read 1465 times)
Pan Switch
« on: May 20, 2005, 11:03:59 AM »
I'm looking to switch the swing axle pan on my '59 to an IRS to avoid the excessive camber when lowered in the back. What kind of legal issues am I looking at here? If I find a pan without papers is this going to cause me problems when I go to insure it with ICBC? Someone out there done this before? Cheers. Jeremy
Pan Switch
« Reply #1 on: May 20, 2005, 11:46:07 AM »
grind off the numbers and dont worry about it
Offline Boost_Retard
Pan Switch
« Reply #2 on: May 20, 2005, 02:44:41 PM »
cut the numbers outa your old pan and weld them into your new pan...
or weld over the new pan numbers and go to lordco and get a set of punches with the #s and letters on them...grind the weld down flat and stamp in new numbers if your worried.
personally ICBC should Fuck off and die as far as im concerned dont worry about those pussys.
bastards
Cale
Pan Switch
« Reply #3 on: May 20, 2005, 02:50:42 PM »
The correct way is to get ownership of the chassis.  Then when you build the car they will inspect the VINs and add the chassis number to your registration with your original's 58 VIN.
Pan Switch
« Reply #4 on: May 20, 2005, 02:53:59 PM »
or ya can do what bruce said :)
i still hate ICBC! CROOKS!! BASTARDS!!! hahahahahhah!! DIE!!
Cale
Pan Switch
« Reply #5 on: May 20, 2005, 04:31:59 PM »
you can borrow my grinder........
