Author Topic: It's Drivin  (Read 1320 times)
It's Drivin
« on: April 25, 2005, 05:35:33 PM »
So after a month of tinkerin, I finally took the 67 through aircare and it passed. I was pretty stoked this mornin! then on the way home I noticed the oil pressure light flicker at idle, I bought a mech. oil gauge and changed the oil to 20w 50, without any success. After a good run out in the country this afternoon (with fresh oil) I brought it back and the pressure read about 4psi at idle and the light started to flicker again. It looks like I may be doing an engine swap sooner then I thought. unless anyone knows how to successfully raise the oil pressure? those booster kits are as usefull as tits on a bull.
It's Drivin
« Reply #1 on: April 25, 2005, 07:16:34 PM »
well drive it well it's nice anyways,
nice to be back behind the wheel of a vw :D
It's Drivin
« Reply #2 on: April 25, 2005, 10:15:58 PM »
Matt, The Oil pump may be worn and not making enough PSI or worse the eng may need a rebuild. For now I'd try one of our 26 or 30 mm oil pumps.
