Author Topic: Installing My Airspeed Drag Bar  (Read 4158 times)
« on: April 23, 2005, 07:54:44 PM »
What modifications are required to the shell of my 61 beetle to accomodate the installation of my drag bar? And do you have any pics?
« Reply #1 on: April 23, 2005, 11:37:55 PM »
You may(or may not) need to slightly widen the holes in the quarters that allow you to tighten up the rear shock bolts. I will try to find you some pics of my install...
-Kirin
« Reply #2 on: April 24, 2005, 05:35:44 PM »
thats the only mod nessesary
search james buchan on thesamba and you will find pics of his install
« Reply #3 on: April 24, 2005, 05:40:20 PM »
i dont have time to go through 15000 posts
Offline Swartz
« Reply #5 on: May 07, 2006, 10:38:02 AM »
Thanks for the pics James. I remembered seeing this along time ago. FINALLY im going to install mine.
Everything takes time
« Reply #6 on: May 08, 2006, 02:37:17 AM »
When I installed the AS bar on Rick's car, I enlarged the holes in the body to just a couple of mm larger than the bar.  This was a mistake since the rear of the pan flexed down once the engine was installed.  You need to make the holes fairly large like James did.
Offline Swartz
« Reply #7 on: May 08, 2006, 05:47:39 PM »
Thanks for the tip. Ill make sure to take a look at it before i throw my motor back in.  :rockon:
