Putting the new front end in the Ghia, I went to put the rotors on and could not get the coupler nut more that three threads on?? So I check clearance on the backside of the rotor and the bearing is not sliding up the shaft, Does anyone know is Drum brake spindels are larger in diameter that disc? Have I been sold a Drum brake front end? I noticed that there is a Clearcoat substance on the spindels, should i take that off. I tried brake clean with no results I dont have a micrometer to measure Spindel diameter but I dont know if the New front ajustable front ends are lacking in the quality department like so many other VW aftermarket items.
Please Help Trying to put together tonight!!
Cheers!
