Hey Jim.
i have the 1 peice mounted on the car..and am having a slight problem with one fender..i was wanting to know if it was this way on your car...and possibly what you did to make it work...
The passenger side tire...when the car is fully slamed..tucks up inside the fender..with some room to spare..i can slide my hand up between the fender and the tire..
on the drivers side..there is no room at all..almost like the fender is a little more narrow than the passenger side..
maybe because you run a 6\"? narrowed beam...and the tire/wheel combo you have up front allowed it to have enough room move..
as i have a 3\" narrowed beam and 195s on chromies up front..
if this is the case im gonna cut the fender to fix it..i just was not sure if i was missing something..
thanks
Cale
