Author Topic: Gas Tank Vent Tube (how To Do?)  (Read 5800 times)
« on: March 08, 2005, 07:33:11 AM »
i would like to vent my gas tank like this on my project car but don't know where to start.
where can i buy fitting's to do this?
i assume one side would be flared and the other would fit into a fitting with another fitting tightening the two together :o  make sense??
any ideas throw them out there
thanks russ
« Reply #1 on: March 08, 2005, 07:36:32 AM »
i think you got it figured out, some hard fuel line, and appropriate fittings, flare it and fire it out the bottom, looks good.
« Reply #2 on: March 08, 2005, 08:31:10 AM »
does anybody know where i can buy the fitting's? lordco?
i would imagine it would be 1/4\" lines.
thanks for the reply
76
russ
« Reply #3 on: March 08, 2005, 03:10:52 PM »
i would imagine it would be 1/4" lines.
76
russ
you hit the nail on the head russ.
Lordco would sell those fittings
Stephan
« Reply #4 on: March 08, 2005, 03:22:42 PM »
mopac sells -an fittings -[but you need a 37 deg flaring tool !!!!!]
« Reply #5 on: March 08, 2005, 04:01:59 PM »
i figured one of the local brake shops would be able to flare it for me
thanks on the tips guys
russ
« Reply #6 on: March 08, 2005, 04:57:26 PM »
flare tool kits at princess auto, cheap.
« Reply #7 on: March 08, 2005, 06:47:32 PM »
just so you know.
the brake flaring kits use a 45 deg flare.
and -an fittings use  a 37 deg flare.
there is a differance.
if anyone is stuck i have a 37 deg flaring tool so if anyone is making aluminum or steel fuel lines etc and is planning on using -an fittings i can help you out
« Reply #8 on: March 08, 2005, 07:02:54 PM »
:blush:  good to know thanks russ
Offline thrasherbill
« Reply #9 on: March 09, 2005, 11:35:04 PM »
Is extra venting needed on an early tank? Looks to me that with a full tank and a left turn you'd be dumping gas out the vent tube with that set up.
ThrasheR
CLICK.
Pinhead Lounge
