Author Topic: Engine Disassembly  (Read 5179 times)
Offline Swartz
Engine Disassembly
« on: March 03, 2005, 09:45:28 PM »
This is my first time taking my engine apart. So i go to split the case but before that i took off my oil pump cover and in my manual im following it says i need a special tool to get the plate off behind it. Does any have the part # for it or can i use a different style puller? Even though it doesnt look like there is anywhere for it to attach to behind it... ;) also is there any thing else i should look out for or pay close attention to?
thanks
« Last Edit: March 03, 2005, 09:52:52 PM by 64dub »
Everything takes time
Engine Disassembly
« Reply #1 on: March 03, 2005, 09:48:29 PM »
just try rocking it out, thats what I did, came out very easy, I didn't use any special tools to dismantle my case.
Offline Swartz
Engine Disassembly
« Reply #2 on: March 03, 2005, 09:48:31 PM »
by the way spelling isnt my strong point!
« Last Edit: March 03, 2005, 09:51:28 PM by 64dub »
Offline Swartz
Engine Disassembly
« Reply #3 on: March 03, 2005, 10:08:22 PM »
that thing is stuck on there! its a brand new case im just taking it apart to bore that bad bitch bigger.
Offline Stevie
Engine Disassembly
« Reply #4 on: March 03, 2005, 10:49:57 PM »
if you don't want to buy the tool
remove two of the oil pump studs  on the same side and when you start to split the case it will create a gap and you can just pull it out :)
20's SORTA FIT!!
63 Beetle
Offline Swartz
Engine Disassembly
« Reply #5 on: March 05, 2005, 05:27:47 PM »
its all apart and sent out to be bored out!
Engine Disassembly
« Reply #6 on: March 07, 2005, 08:44:25 PM »
who's doing the machine work?
make sure when they face the deck that the same amount of material is removed from both case halfs
Offline Swartz
Engine Disassembly
« Reply #7 on: March 07, 2005, 09:22:20 PM »
i returned it to airspeed where i purchased it and they are sending it out for me
