Technical
Window Seals
Topic: Window Seals (Read 3250 times)
Mike Scott
Window Seals
February 19, 2005, 06:29:38 PM »
I've got the installation of the seal down except, the chrome trim. Does it go after the window is installed or should I put it in the grove prior to installation?
Mike
red snapper
Window Seals
February 22, 2005, 12:05:57 PM »
OH! the dreaded chrome trim! What you do is put the rubber on the windshield then the chrome, then install the window all as one. Use some silicone inside the channel where the chrome goes. Good luck, Brian.
Mike Scott
Window Seals
February 22, 2005, 12:09:41 PM »
Thanks Brian,
Time to remove the rear window and try again, ]
with chrome this time
Mike
Technical
Window Seals
