Author Topic: Engine Assy Q's  (Read 3703 times)
Engine Assy Q's
« on: February 10, 2005, 10:12:05 PM »
So after all this time I finally managed to put some time into the assembly of my new motor
I am building a 1914, figure if I am going to f*** something up I will go small, anyway.
First question, did some reading but nothing really touched on this, I installed the new cam bearings and noticed that they dont fit in flush to the case, do I need to trim this and what method would you recommend?
I would think filing them flush would work but then I am not sure as to whether its needed, would they not press into place after closing the case?
TYIA
Engine Assy Q's
« Reply #1 on: February 10, 2005, 10:32:58 PM »
You just press them into place with your fingers, The only one that may have a issue is the DBL thrust bearing, you may need to file a notch in the case to allow that one to fit.
