Air Speed Lounge
Bolt Patterns
Topic: Bolt Patterns (Read 1280 times)
reefreshd_jive
Bolt Patterns
January 07, 2005, 05:18:50 PM »
i am just wondering, if anyone knows if a 5x100 pattern can be drilled onto my 4x130 discs, and rear drums...i have drawn it out, and i think it will work, but i am not 100% sure. just want to make sure
thanks.
Hoosier Daddy
Bolt Patterns
January 07, 2005, 05:20:49 PM »
I think you can....check the back though to see how much metal is there...if you hit up a tire shop they have these metal plates with all different wheel patterns, maybe you could line it up to see.
Bruce
Bolt Patterns
January 08, 2005, 03:03:35 PM »
The only problem you may encounter is the overlap of one bolt. Since you have drawn it out, what's the overlap look like? If you have even 1mm you are ok.
Air Speed Lounge
Bolt Patterns
