Author Topic: Wrist Pins Needed For 90.5-92 -94mm P&c  (Read 1143 times)
« on: January 06, 2005, 12:53:31 PM »
A friend needs a set of 4 wrist pins from cima P&C set. must be from  90.5-92or 94mm set. the length is 75mm used are perfect.
Geoff.
« Reply #1 on: January 06, 2005, 03:24:53 PM »
AFAIK, the 90.5 pins are shorter than the 94 pins.  You can use stock 1600 wrist pins in place of 90.5 pins, they are the same length, and as a bonus are lighter.  I will be liberating a set of 90.5 pins next time the engine is apart, but that might not be for another 5-10 years.
« Reply #2 on: January 06, 2005, 04:25:55 PM »
Sorry Bruce Your information is not correct. The Cima 90.5 to 94 pins are all the same length 75mm and the teflon button makes up the difference when instaled. The stock wrist pin is 72mm and will not work, Maybe the old NPR wrist pins may be what you are talking about. But yes the stock ones are much lighter due to their larger ID.
