Author Topic: Mag Case  (Read 4191 times)
Mag Case
« on: December 30, 2004, 10:18:18 AM »
i plan on running a 1914 or a 2007 combo in a mag case.
my question is what do people generally have done to the cases to improve them?
have the lifter bores sleeved? and help on the subject would be great as i am pretty clueless on the whole issue :wub:
thanks russ
Offline Hoosier Daddy
Mag Case
« Reply #1 on: December 30, 2004, 10:30:18 AM »
All I did to mine was put Case Savers in.
Mag Case
« Reply #2 on: December 30, 2004, 10:44:08 AM »
I had mine clearanced for stroker - saves doing it next build.
Full Flowed
Shuffle Pined
Opened for 94's
Case savers installed
And matched the two halves - to ensure they mate properly.
Check you don't need a line bore while your at it.
Mag Case
« Reply #3 on: January 02, 2005, 01:41:58 PM »
Presumeably you want an engine that will live a long life, not a grinade engine like some of the guys here have.  With that assumption you will not be using a cam that is very big, or springs that are really stiff.  You don't need to sleeve your lifter bores.
« Last Edit: January 02, 2005, 01:42:30 PM by Bruce »
