Author Topic: Splitting A Case  (Read 4793 times)
Splitting A Case
« on: December 25, 2004, 01:47:51 PM »
Whats the best way? I am just ready to split mine and have all the hardware removed, and double checked, oil pump is out, and the case is starting to split at the oil pump end but not at the flywheel, I am not missing anything behine the flywheel am I? I dont think I am, anyway what do you all suggest?
Offline Hoosier Daddy
Splitting A Case
« Reply #1 on: December 25, 2004, 02:30:38 PM »
You got all the rear bolts out?
Splitting A Case
« Reply #2 on: December 25, 2004, 03:22:36 PM »
You got the small nut(8mm) just under / beside the bottom right (as you look at it)  BIG case stud nut and another  about 1  1/2 \"  below that?
No , nothing behind the flywheel
« Last Edit: December 25, 2004, 03:24:27 PM by Hansk »
Splitting A Case
« Reply #3 on: December 25, 2004, 09:14:04 PM »
Yep, I am sure I got them all, just not going to force anything apart.
Splitting A Case
« Reply #4 on: December 25, 2004, 10:03:11 PM »
ah ha! I found one covered in dirt, case came apart easily after that!
Splitting A Case
« Reply #5 on: December 26, 2004, 10:35:46 AM »
:lol: there's always one that gets me every time :lol:
Splitting A Case
« Reply #6 on: December 26, 2004, 02:35:32 PM »
There's actually 2 M8 nuts that hide under the gunk.  They are above and below the camshaft's centerline.
